Overview
CyberPi is a main control board independently developed by Makeblock. With a compact structure and built-in ports, it can easily be extended. It supports mBlock 5 and mBlock-Python Editor, and it is applicable to multiple education scenarios including large-class teaching, community teaching, and online/offline education and training. It covers multiple teaching fields including coding, makers, and robots, and thus it can meet diversified education needs, such as AI, IoT, data science, and UI design.
More information:
Specifications
| Name | CyberPi | |
| Chip | ESP32-WROVER-B | |
| Processor | Main processor | Xtensa® 32-bit LX6 dual-core |
| Clock frequency | 240 MHz | |
| Onboard memory | ROM | 448 KB |
| SRAM | 520 KB | |
| Extended memory | SPI Flash | 8 MB |
| PSRAM | 8 MB | |
| Operating system | CyberOS, independently developed by Makeblock | |
| Wireless communication |
Wi-Fi Dual-mode Bluetooth |
| Ports |
Micro USB port (Type-C) Port for connecting to extension boards Port for connecting to electronic modules (serial communication) |
| Hardware version | V1.0 | |
| Dimensions | 84 mm x 35 mm × 13 mm (height × width × depth) | |
Weight
36 g | |
Features
Full-color display, providing user-friendly UIs for human-machine interaction
CyberOS system, allowing you to execute the predefined programs, set the system language, and update the system through the onboard joystick and buttons
One Micro USB port (Type-C) for connecting to PCs for power supply and communication
One electronic module port for connecting to electronic modules
One extension board port for connecting to extension boards
Multiple onboard sensors, such as light sensor and gyroscope, which provide multiple types of data
Five LEDs, allowing you to present abundant light effects
Onboard Bluetooth and Wi-Fi modules, enabling wireless communication
Support programming with mBlock 5, which is intended for all ages, including those without any programming experience
Support Python programming, for which the
cyberpilibrary is provided
Dimensions
Port description
CyberPi is equipped with a USB Type-C port, a port for connecting to electronic modules, and a port for connecting to extension boards, which allow CyberPi to easily and quickly connect to various types of electronic modules and extension boards.
The Micro USB port allows CyberPi to connect to various types of computer devices for power supply and communication.
You can easily and quickly connect CyberPi to an extension board through the extension board port. Currently, the extension board Pocket Shield is available for CyberPi.Pocket Shield is equipped with a built-in rechargeable battery that can supply power for CyberPi and provides 2-pin and 3-pin interfaces that can be used to connect to servos, LED strips, and motors, which significantly improves the extensibility of CyberPi.
For more information, see Pocket Shield.
You can connect CyberPi to multiple electronic modules in series through the electronic module port.CyberPi can identify the addresses of the modules, which simplifies your programming. You don't have to set the information about the addresses of the modules when you add or remove a module.
Example:
Connect CyberPi to multiple LED matrixes
Change the positions of the modules, as shown in the following figure.
For more information about mBuild modules, see mBuild Modules.
Programming
You can use mBlock 5 to program CyberPi. mBlock 5 provides two editors, namely the block-based graphical editor (the default editor, referred to as mBlock 5) and Python editor (referred to as mBlock-Python Editor).For details about programming, see Programming Software.
I will study this Interesant Hardware.
Thank s
