List of items
Meet your Laserbox
Laserbox
1 Button 2 Annular indicator 3 Power button 4 Power interface 5 USB interface 6 Ethernet cable interface 7 Smoke outlet 8 Aviation interface |
9 Camera 10 Laser head 11 Tray 12 Honeycomb panel 13 Laser tube |
Smart smoke purifier
1 Filter 2 Indicator 3 Aviation interface 4 Smoke inlet 5 Smoke outlet |
Annular indicator status
| Indicator Status | Description |
| Blinking white | Being started |
| Solid white | Waiting to be connected |
| Blinking blue | Ready. The design has been received. |
| Solid blue | Standby. The machine has been connected to a PC. |
| Six LEDs lit up one by one | Operating. LEDs light up one by one, indicating the progress of the engraving or cutting. |
| Solid green |
Process completed |
| Breathing green | Sleep state, entered if no operation is performed in 10 minutes |
| Solid red | Exceptions occurring |
| Solid purple | Firmware being upgrading |
Download and install Laserbox
Download Laserbox
Laserbox is a laser engraving software designed by Makeblock.
The software features many capabilities that let you make the most out of Laserbox. It also provides essential design tools that you can depend on to create different shapes and add filters to your design. To download Laserbox, click here.
Install Laserbox
1. Run installer
Run the Laserbox installer you just downloaded.
2. Choose destination location
Choose the folder into which you're going to install Laserbox. Click Next to continue.
3. Select additional tasks
Follow the on-screen prompts to select any of the additional tasks you want to perform, including adding a folder to the Start menu or creating a desktop shortcut. Click Install to start the installation.
4. Finish
After the installation is complete, click Finish to exit the installer.
Connect devices
Connect the smart smoke purifier to Laserbox
- Plug the 2 m exhaust pipe into the purifier and lead the pipe to the window.
- Connect Laserbox and the purifier with the 1.5 m exhaust pipe.
- Connect Laserbbox and the purifier with the aviation connector.
- Connect Laserbox to a power supply.
Start Laserbox for the first time
The laser head automatically resets and calibrates after you press the power button. When the first startup is complete, the annular indicator will turn solid white. The startup process takes a while, so please be patient.
Connect Laserbox to a computer
Connect via USB cable
1. Use a USB cable to connect Laserbox to your computer.
2. Open the software Laserbox, choose your Laserbox model, then click Next.
3. Select USB, then click Next to connect Laserbox to the computer.
4. Laserbox is succussfully connected to the computer.
Connect via Ethernet cable (not included in the package)
1. Use an Ethernet cable to connect Laserbox to your computer.
3. Select Ethernet, then click Next to connect Laserbox to the computer.
Connect via Wi-Fi
3. Select Wi-Fi, then click Next to connect Laserbox to the computer.
4. Choose an available Wi-Fi network and enter its name and password.
5. Remove the USB cable when successfully connected to a Wi-Fi network. When the computer and the laser cutter are on the same Wi-Fi network, you can wirelessly control the laser cutter using the software Laserbox.
Connect to a networked Laserbox
1. Ensure your computer and the laser cutter are on the same Wi-Fi network.
2. Open the software Laserbox, select Scan device connected in LAN.
3. Select the device you'd like to connect from the list. Click Next.
