Case 5 - mBot2 Rover senses the shaking strength
Part 1 Objective
After uploading the program, you can shake mBot2 Rover to change its expression.
Part 2 Preparation
  • Assembled mBot2 Rover × 1
  • USB cable (Type-C) × 1
  • Computer with network access × 1
Turn on mBot2 Rover and connect it to the computer by using the cable. Open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3 Programming
Click + extension on mBlock 5, and add Display+.
Write the following program, and upload it to CyberPi. Then you can shake mBot2 Rover to change its expression.
Part 4 Practice
Try shaking mBot2 Rover to make it move back and forth.
1 out of 1 found this helpful
