About mBot Mega
Overview
mBot Mega is a programmable metal-structured robot. It provides the automatic gesture recognition, line following, and obstacle avoidance functions and supports mBlock block-based programming, Arduino IDE programming and Raspberry Pi interfaced. mBot Mega is equipped with four Mecanum wheels. Compared to regular wheels, the Mecanum wheels allow mBot Mega to move more flexibly and in more modes, making it a better choice for learning robot motion algorithms.
Let's explore more together!
Building mBot Mega
Before you use mBot Mega, you need to build it. See Building mBot Mega.
Updating firmware
Before you use mBot Mega, you need to update its firmware on mBlock first. For details, see Updating the Firmware of mBot Mega.
Tips: Before you use mBot Mega, make sure that you put batteries with sufficient power into the battery holder and then turn on the power switch. If the batteries are running low, the motors of mBot Mega can't be started.
3 out of 3 found this helpful
