Case 7 - Voice-activated RGB LEDs (II)
Part 1   Objective
After you upload the program, when you play music, the brightness of the RGB LEDs on the xLight wooden base, LED strip, or LED string changes with the loudness detected by the microphone.
Part 2   Preparation
  • xLight control box x 1
  • USB cable (Type-C) x 1
  • Wooden base or LED strip or LED string
Connect the wooden base, LED strip, or LED string to the xLight control box, connect the xLight control box to the computer by using the cable, open mBlock 5 (PC client or web version), delete the default device, click +add, select xLight from the Device Library and then click Set as mostly used device in the upper left corner, click Connect, and select the Upload mode.
Part 3   Programming
Set the light color of the RGB LEDs on the wooden base as red, and use Sensing blocks to control the brightness of the RGB LEDs with the loudness detected by the microphone.
Part 4   Practice
Try to control the change of the light color of the RGB LEDs.
0 out of 0 found this helpful
