Case 20 - Dancing
Case 20 - Dancing
Part 1   Objective
After you upload the program, Codey Rocky can shake and move forward, backward, left and right with dynamic lighting effects and sounds, looking like it is dancing.
Part 2   Preparation
  • Assembled Codey Rocky x 1
  • USB cable x 1
Part 3   Programming
Use Emotion blocks, Action blocks and Lighting blocks, and click Upload to make Codey Rocky dance.
Part 4   Practice
Try to add more actions, sounds and lighting effects to make Codey Rocky dance in different ways.
0 out of 0 found this helpful
