Case 20 - Codey Rocky dances
Part 1   Objective
After you upload the program, Codey Rocky can shake and move forward, backward, left, and right with dynamic lighting effects and sounds, looking like it is dancing.
Part 2   Preparation
  • Assembled Codey Rocky x 1
  • USB cable x 1
Connect Codey to the computer by using the USB cable, open mBlock 5 (PC client or web version), delete the default device, click +add, select Codey from the Device Library and then click Set as mostly used device in the upper left corner, click Connect, and select the Upload mode.
Part 3   Programming
Use Emotion blocks, Action blocks, and Lighting blocks, and click Upload to make Codey Rocky dance.
Part 4   Practice
Try to add more actions, sounds, and lighting effects to make Codey Rocky dance in different ways.
4 out of 7 found this helpful
