Case 18 - Obstacle Avoidance
Part 1 Objective
Make Codey Rocky turn left or right when it encounters an obstacle and move forward after it passes the obstacle.
Part 2 Preparation
Assembled Codey Rocky x 1
USB cable x 1
Part 3 Programming
Turn the IR color sensor at the bottom of Codey Rocky to be at the front of it. Use Action blocks, Control blocks and Sensing blocks, and click Upload to make Codey Rocky start moving forward when you press button A, turn left or right randomly when it encounters an obstacle, and move forward after it passes the obstacle.
Part 4 Practice
Make a track with multiple obstacles on and let Codey Rocky pass the obstacles.
