Case 17 - Turning Left and Right
Part 1 Objective
Make Codey Rocky turn left and right.
Part 2 Preparation
Assembled Codey Rocky x 1
USB cable x 1
Part 3 Programming
Use Action blocks and click Upload to make Codey Rocky start turning left and right when you press button A and make it stop turning when you press button B.
Part 4 Practice
Try to make Codey Rocky move forward and backward, and turn left and right.
Try to control the angles Codey Rocky turning left and right.
