Part 1 Objective
Make Codey Rocky turn left and right.
Part 2 Preparation
Assembled Codey Rocky x 1
USB cable x 1
Connect Codey to the computer by using the USB cable, open mBlock 5 (PC client or web version), delete the default device, click +add, select Codey from the Device Library and then click Set as mostly used device in the upper left corner, click Connect, and select the Upload mode.
Part 3 Programming
Use Action blocks and click Upload to make Codey Rocky start turning left and right when you press button A and make it stop turning when you press button B.
Part 4 Practice
Try to make Codey Rocky move forward and backward, and turn left and right.
Try to control the angles at which Codey Rocky turns left and right.
