Case 16 - Moving Forward and Backward
Part 1 Objective
Make Codey Rocky move forward and backward.
Part 2 Preparation
Assembled Codey Rocky x 1
USB cable x 1
Part 3 Programming
Use Action blocks and click Upload to make Codey Rocky start moving forward and backward when you press button A and make it stop moving when you press button B.
Part 4 Practice
Try to control the speed for Codey Rocky to move forward and backward.
Try to control the distance Codey Rocky moves forward and backward.
