Case 10 - Display of Weather Conditions
Part 1   Objective
Use IoT blocks to connect to the network, select a city to obtain its weather condition, then Codey's screen displays the weather condition of the city.
Part 2   Preparation
  • Codey (robot controller) x 1
  • USB cable x 1
Part 3   Programming
  1. Click + extension and then click + Add below IoT.
  2. Use IoT blocks together with Looks blocks and Control blocks, and click Upload to obtain and display the weather condition of a city.
Part 4   Practice
  1. Try to obtain the weather condition and temperature of your city.
  2. Try to display the weather condition, the maximum temperature and the minimum temperature of your city in turn.
0 out of 0 found this helpful
