Case 9 - Display of Codey's Postures
Part 1   Objective
After you upload the program, Codey's screen displays the angle Codey is tilted to the left or right in real time.
Part 2   Preparation
  • Codey (robot controller) x 1
  • USB cable x 1
Part 3   Programming
Use the reset the ( ) rotation angle ° block and the rotation angle around y block in Sensing blocks and the show ( ) block in Looks blocks, and click Upload to display the angle Codey is tilted to the left or right.
Part 4   Practice
  1. Try to make Codey play a specific sound when it is tilted to the left or right.
  2. Try to display the angle Codey is tilted forward or backward, or the angle Codey is rotated.
0 out of 0 found this helpful
