Case 8 - Display of Shaking Strength
Part 1   Objective
After you upload the program, Codey's screen displays the shaking strength when you shake it.
Part 2   Preparation
  • Codey (robot controller) x 1
  • USB cable x 1
Part 3   Programming
Use the shaking strength block in Sensing blocks and the show ( ) block in Looks blocks, and click Upload to display the shaking strength when you shake Codey.
Part 4   Practice
Try to make Codey play a specific sound when you shake it.
0 out of 0 found this helpful
