Case 7 - Display of Battery Level
Part 1 Objective
After you upload the program, Codey's screen displays its current battery level.
Part 2 Preparation
Codey (robot controller) x 1
USB cable x 1
Part 3 Programming
Use the battery level block in Sensing blocks and the show ( ) block in Looks blocks, and click Upload to display the battery level in real time.
Part 4 Practice
Try to make Codey play a specific sound when it is fully charged.
