Case 7 - Display the battery level
Part 1   Objective
After you upload the program, Codey's screen displays its current battery level.
Part 2   Preparation
  • Codey (robot controller) x 1
  • USB cable x 1
Connect Codey to the computer by using the USB cable, open mBlock 5 (PC client or web version), delete the default device, click +add, select Codey from the Device Library and then click Set as mostly used device in the upper left corner, click Connect, and select the Upload mode.
Part 3   Programming
Use the battery level block in Sensing blocks and the show ( ) block in Looks blocks, and click Upload to display the battery level in real time.
Part 4   Practice
Try to make Codey play a specific sound when it is fully charged.
3 out of 5 found this helpful
