Case 6 - Display of Ambient Light Intensity
Part 1   Objective
After you upload the program, Codey's screen displays the current light intensity. Codey's light sensor is at the small hole in the lower right corner.
Part 2   Preparation
  • Codey (robot controller) x 1
  • USB cable x 1
Part 3   Programming
Use the ambient light intensity block in Sensing blocks and the show ( ) block in Looks blocks, and click Upload to display the ambient light intensity value in real time.
Part 4   Practice
  1. Try to record the outdoor light intensity values at different time points of a day.
  2. Try to make Codey detect and tell whether it is in the daytime or at night.
0 out of 0 found this helpful
