Case 5 - Display of Gear Potentiometer Value
Part 1 Objective
After you upload the program, Codey's screen displays the output value of the gear potentiometer.
Part 2 Preparation
Codey (robot controller) x 1
USB cable x 1
Part 3 Programming
Use the gear potentiometer value block in Sensing blocks and the show ( ) block in Looks blocks, and click Upload to display the output value of the gear potentiometer in real time.
Part 4 Practice
Roll the gear potentiometer and see if the value changes.
Can you use the gear potentiometer together with other modules mentioned in the preceding cases to control the display of light intensity, sound volume or sound frequency?
