Case 4 - Beeps
Part 1   Objective
Make Codey keep beeping.
k4p1v.mp4
Part 2   Preparation
  • Codey (robot controller) x 1
  • USB cable x 1
Connect Codey to the computer by using the USB cable, open mBlock 5 (PC client or web version), delete the default device, click +add, select Codey from the Device Library and then click Set as mostly used device in the upper left corner, click Connect, and select the Upload mode.
Part 3   Programming
Use the play sound at frequency of ( ) HZ for ( ) secs block in Speaker blocks and the wait ( ) seconds block in Control blocks, and click Upload to make Codey keep beeping.
Part 4   Practice
  1. Try to change the sound frequency and see how the sound changes.
  2. Try to use other Speaker blocks to make different sounds.
1 out of 2 found this helpful
