Case 3 - Control of RGB LED Indicator
Part 1 Objective
After you upload the program, Codey's RGB LED indicator blinks.
Part 2 Preparation
Codey (robot controller) x 1
USB cable x 1
Part 3 Programming
Use the RGB LED lights up ( ) block in Lighting blocks and the wait ( ) seconds block in Control blocks, and click Upload to make the RGB LED indicator blink.
Part 4 Practice
Try to change the blinking frequency of the RGB LED indicator.
Try to change the color of the RGB LED indicator.
