Case 2 - Facial Expression DIY
Part 1 Objective
After you upload the program, Codey blinks when you press button A.
Part 2 Preparation
Codey (robot controller) x 1
USB cable x 1
Part 3 Programming
Drag and drop the when button ( ) is pressed block from Events blocks, drag and drop the show image ( ) block from Looks blocks, and drag and drop the wait ( ) seconds block from Control blocks to the Scripts area for facial expression DIY, and click Upload to make Codey blink.
Part 4 Practice
Try to change Codey's blinking frequency.
Can you design other facial expressions for Codey?
Try to use other Looks blocks, for example, the show hello block. You can also use the light up x: ( ) y: ( ) block to light up a certain LED on Codey's screen.
