Case 2 - DIY facial expressions
Part 1   Objective
After you upload the program, Codey blinks when you press button A.
Part 2   Preparation
  • Codey (robot controller) x 1
  • USB cable x 1
Connect Codey to the computer by using the USB cable, open mBlock 5 (PC client or web version), delete the default device, click +add, select Codey from the Device Library and then click Set as mostly used device in the upper left corner, click Connect, and select the Upload mode.
Part 3   Programming
Drag and drop the when button ( ) is pressed block from Events blocks, drag and drop the show image ( ) block from Looks blocks, and drag and drop the wait ( ) seconds block from Control blocks to the scripts area for facial expression DIY, and then click Upload to make Codey blink.
Part 4   Practice
  1. Try to change Codey's blinking frequency.
  2. Can you design other facial expressions for Codey?
  3. Try to use other Looks blocks, for example, the show hello block. You can also use the light up x: ( ) y: ( ) block to light up a certain LED on Codey's screen.
1 out of 2 found this helpful
