Case 1 - Codey Rocky's Emotion Expression
Part 1 Objective
After you upload the program, Codey Rocky expresses its happiness with a happy face, laughter and movement when you press button A.
Part 2 Preparation
Assembled Codey Rocky x 1
USB cable x 1
Part 3 Programming
Drag and drop the when button ( ) is pressed block from Events blocks and drag and drop the smile block from Emotion blocks to the Scripts area, and click Upload.
Part 4 Practice
Try to make Codey Rocky express other emotions.
