Case 1 - Codey Rocky expresses emotions
Part 1   Objective
After you upload the program, Codey Rocky expresses its happiness with a happy face, laughter, and movement when you press button A.
Part 2   Preparation
  • Assembled Codey Rocky x 1
  • USB cable x 1
Connect Codey to the computer by using the USB cable, open mBlock 5 (PC client or web version), delete the default device, click +add, select Codey from the Device Library and then click Set as mostly used device in the upper left corner, click Connect, and select the Upload mode.
Part 3   Programming
Drag and drop the when button ( ) is pressed block from Events blocks and drag and drop the smile block from Emotion blocks to the scripts area, and click Upload.
Part 4   Practice
Try to make Codey Rocky express other emotions.
12 out of 18 found this helpful
