Case 23 - Robotic Ant (I)
Part 1   Objective
Write a program to make Robotic Ant move forward and backward.
Part 2   Preparation
  • Mechanical parts and electronic modules of Robotic Ant
  • USB cable (Type-B) x 1
Follow the building steps to build Robotic Ant. Install the MegaPi encoder/DC motor drivers on MegaPi, connect the motors to the motor ports on MegaPi by using the motor cables, connect MegaPi to the computer by using the USB cable, open mBlock 5 (PC client, web version, or mobile app), click +add, select Ultimate 2.0 from Device Library, click Connect, and select the Upload mode.
Part 3   Programming
In Upload mode, when Ultimate 2.0 (MegaPi) starts up, Robotic Ant stops moving and starts moving forward and backward 2 seconds later. Robotic Ant moves forward for 2 seconds and then moves backward for 2 seconds, and repeats this process.
Part 4   Practice
Try to set different power values and durations for Robotic Ant to move forward and backward, and see what the difference is.
0 out of 0 found this helpful
