Case 22 - Rolling Tank
Part 1   Objective
Write a program to make the Rolling Tank cross an obstacle by moving forward, backward, left, and right.
Part 2   Preparation
  • Mechanical parts and electronic modules of Rolling Tank
  • USB cable (Type-B) x 1
Follow the building steps to build a Rolling Tank. Install the MegaPi encoder/DC motor drivers on MegaPi, connect the motors to the motor ports on MegaPi by using the motor cables, connect MegaPi to the computer by using the USB cable, open mBlock 5 (PC client or web version), click +add, select Ultimate 2.0 from the Device Library, click Connect, and select the Live mode.
Update the firmware of Ultimate 2.0.
Part 3   Programming
Part 4   Practice
Try to add more obstacles.
2 out of 6 found this helpful
