Part 1 Objective
Write a program to make the Robotic Bartender perform the action of pouring wine.
Part 2 Preparation
Mechanical parts and electronic modules of Robotic Bartender
USB cable (Type-B) x 1
Follow the building steps to build a Robotic Bartender. Install the MegaPi encoder/DC motor drivers on MegaPi, connect the motors to the motor ports on MegaPi by using the motor cables, connect MegaPi to the computer by using the USB cable, open mBlock 5 (PC client or web version), click +add, select Ultimate 2.0 from the Device Library, click Connect, and select the Upload mode.
Part 3 Programming
Make the Robotic Bartender repeat the action of pouring wine by using the motor rotation angle control and action repeat blocks.
Part 4 Practice
Try to use other objects and make adjustments to find the optimal motor rotation angle.
