Case 9 - Use a motor to control another motor
Part 1   Objective
After you compile the program, you can control the rotation speed and direction of motor 2 by rotating motor 1.
Part 2   Preparation
  • MegaPi x 1
  • MegaPi RJ25 adapter x 1
  • RJ25 cable x 1
  • MegaPi encoder/DC motor driver x 2
  • Photoelectric encoder motor 185RPM with wheel × 2
  • Encoder motor cable x 2
  • USB cable (Type-B) x 1
  • Battery holder with 6 AA batteries x 1
Install the MegaPi RJ25 adapter and the MegaPi encoder/DC motor drivers on MegaPi, connect the encoder motors to MegaPi by using the encoder motor cables, connect the battery holder to MegaPi, connect MegaPi to the computer by using the USB cable, open mBlock 5 (PC client or web version), click +add, select Ultimate 2.0 from the Device Library, click Connect, and select the Live mode.
Part 3   Programming
Set the rotation speed of the motor connected to port 2 as that of the motor connected to port 1. You can set the rotation speed of the motor connected to port 2 fifty times (or any other times) that of the motor connected to port 1 for a more obvious effect.
Part 4   Practice
Try to write a program with other motor-related blocks.
0 out of 0 found this helpful
