Case 5 - Control the rotation of the encoder motor shaft
Part 1   Objective
After you compile the program, the encoder motor shaft rotates at 50% power.
Part 2   Preparation
  • MegaPi x 1
  • Battery holder x 1
  • MegaPi encoder/DC motor driver x 1
  • MegaPi RJ25 adapter x 1
  • RJ25 cable x 1
  • Photoelectric encoder motor 25mm x 1
  • Plastic wheel 90T x 1
  • Shaft connector 4mm x 1
  • Grub screw x 2
  • Encoder motor cable 25mm x 1
  • USB cable (Type-B) x 1
Install the MegaPi RJ25 adapter on MegaPi, connect the encoder motor to MegaPi by using the RJ25 cable, connect the battery holder to MegaPi, connect MegaPi to the computer by using the USB cable, open mBlock 5 (PC client or web version), click +add, select Ultimate 2.0 from the Device Library, click Connect, and select the Live mode.
Update the firmware of Ultimate 2.0.
Part 3   Programming
Drag and drop the encoder motor port 1 rotates at power 50% block to the scripts area, change port 1 to port 4, and then click the block.
Part 4   Practice
Try to write a program to make the encoder motor shaft rotate 360 degrees.
1 out of 3 found this helpful
