Case 2 - Detect the black color
Part 1   Objective
After you compile the program, the stage displays whether the line follower sensor detects the black color in real time.
Part 2   Preparation
  • MegaPi x 1
  • MegaPi RJ25 adapter x 1
  • Line follower sensor x 1
  • RJ25 cable x 1
  • USB cable (Type-B) x 1
Install the MegaPi RJ25 adapter on MegaPi, connect the line follower sensor to MegaPi by using the RJ25 cable, connect MegaPi to the computer by using the USB cable, open mBlock 5 (PC client or web version), click +add, select Ultimate 2.0 from the Device Library, click Connect, and select the Live mode.
Update the firmware of Ultimate 2.0.
Part 3   Programming
After you turn on Ultimate 2.0, the stage displays whether the line follower sensor detects the black color in real time.
Part 4   Practice
Try to detect the white color.
3 out of 5 found this helpful
