Case 14 - mBot Mega follows lines
Part 1   Objective
After you upload the program, mBot Mega moves forward, following the black line on the map.
Part 2   Preparation
  • Assembled mBot Mega x 1
  • USB cable x 1
Connect mBot Mega to the computer by using the cable, open mBlock 5 (PC client or web version), click +add, select mBot Mega from the Device Library, click Connect, and select the Upload mode.
Note: Install the Mecanum wheels correctly and connect the cables according to the user manual for mBot Mega.
Part 3   Programming
mBot Mega moves forward along the black line on the map.
Part 4   Practice
  1. Draw a map on a white paperboard with a black watercolor pen, and see if mBot Mega can move forward along the black line.
  2. Write a program where the paperboard is black and the line is white.
2 out of 4 found this helpful
