Case 12 - Robot Dancing
Part 1   Objective
After you upload the program, the mBot Mega robot performs a sequence of dance movements.
Part 2   Preparation
  • Assembled mBot Mega robot x 1
  • USB cable x 1
Connect the mBot Mega robot to the computer by using the cable, open mBlock 5 (PC client, web version, or mobile app), click +add, select mBot Mega from the Device Library, click Connect, and select the Upload mode.
Note: Please correctly install the Mecanum wheels and connect the cables according to the user manual for mBot Mega.
Part 3   Programming
  1. The mBot Mega robot moves forward for 1 second, moves backward for 1 second, turns left for 1 second, turns right for 1 second, moves left for 1 second, moves right for 1 second, moves 45 degrees toward the upper left for 1 second and then moves 45 degrees toward the upper right for 1 second, and repeats this process. For the specific programming mode, refer to Case 8 - Moving Forward and Backward.
Part 4   Practice
  1. Try to add LED light color changes to the robot.
  2. Try to change the robot's dance movements.
0 out of 0 found this helpful
