Case 11 - Moving 45 Degrees
Part 1 Objective
After you upload the program, the mBot Mega robot moves 45 degrees toward the upper left and then moves 45 degrees toward the upper right, and repeats this process.
Part 2 Preparation
Assembled mBot Mega robot x 1
USB cable x 1
Connect the mBot Mega robot to the computer by using the cable, open mBlock 5 (PC client, web version, or mobile app), click +add, select mBot Mega from the Device Library, click Connect, and select the Upload mode.
Note: Please correctly install the Mecanum wheels and connect the cables according to the user manual for mBot Mega.
Part 3 Programming
The mBot Mega robot moves 45 degrees toward the upper left for 1 second and then moves 45 degrees toward the upper right for 1 second, and repeats this process. For the specific programming mode, refer to Case 8 - Moving Forward and Backward.
Part 4 Practice
Try to change the motor power.
Try to change the interval between movements.
