Part 1 Objective
After you upload the program, mBot Mega moves 45 degrees toward the upper left and then moves 45 degrees toward the upper right, and repeats this process.
Part 2 Preparation
Assembled mBot Mega x 1
USB cable x 1
Connect mBot Mega to the computer by using the cable, open mBlock 5 (PC client or web version), click +add, select mBot Mega from the Device Library, click Connect, and select the Upload mode.
Note: Install the Mecanum wheels correctly and connect the cables according to the user manual for mBot Mega.
Part 3 Programming
mBot Mega moves 45 degrees toward the upper left for 1 second and then moves 45 degrees toward the upper right for 1 second, and repeats this process. For the specific programming mode, refer to Case 8 - mBot Mega moves forward and backward.
Part 4 Practice
Try to change the motor power.
Try to change the interval between movements.
