Case 7 - Marquee
Part 1   Objective
After you upload the program, the RGB LEDs on the RGB module connected to pin A13 on MegaPi light up in turn, achieving the marquee effect.
Part 2   Preparation
  • MegaPi x 1
  • RGB module x 1
  • 3-pin jumper x 1
  • USB cable x 1
Connect MegaPi to the computer by using the cable, connect the RGB module to MegaPi by using the jumper, open mBlock 5 (PC client or web version), click +add, select mBot Mega from the Device Library, click Connect, and select the Upload mode.
Part 3   Programming
The RGB LEDs light up one by one in turn.
Part 4   Practice
  1. Try to change the light color of the RGB LEDs.
  2. Try to change the change speed and light-up sequence of the RGB LEDs.
1 out of 3 found this helpful
