Case 1 - Control the LEDs
Part 1   Objective
After you upload the program, the RGB LEDs on the RGB module connected to pin A13 on MegaPi blink and light up one by one.
Part 2   Preparation
  • MegaPi x 1
  • RGB module x 1
  • 3-pin jumper x 1
  • USB cable x 1
Connect MegaPi to the computer by using the cable, connect the RGB module to MegaPi by using the jumper, open mBlock 5 (PC client or web version), click +add, select mBot Mega from the Device Library, click Connect, and select the Upload mode.
Part 3   Programming
1. When you turn on mBot Mega, the RGB LEDs are on and off alternatively.
2. When you turn on mBot Mega, the RGB LEDs on the RGB module light up one by one. After all the RGB LEDs are on, they go off.
Part 4   Practice
  1. Try to change the light color of the RGB LEDs.
  2. Try to make the RGB LEDs light up and then go off one by one.
7 out of 9 found this helpful
