Case 31 - mBot Neo Follows Objects
Part 1   Objective
After you upload the program, mBot Neo moves straight forward. When the object to be followed is less than 40 cm away from mBot Neo, mBot Neo starts following. When the object to be followed is more than 40 cm or less than 8 cm away from mBot Neo, tmBot Neo stops moving.
Part 2   Preparation
  • Assembled mBot Neo x 1
  • USB cable (Type-C) x 1
Assemble mBot Neo, connect CyberPi to the computer by using the cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3   Programming
Add mBot2 shield and Ultrasonic Sensor 2 from the Extension center, and then program with the blocks added.
Part 4   Practice
Take your "new pet" to travel around your house.
7 out of 13 found this helpful
