Case 29 - mBot Neo Accelerates the Move Forward
Part 1   Objective
After you upload the program, toggle the joystick up and down to set the acceleration of mBot Neo, and then press button A to start mBot Neo.
Part 2   Preparation
  • Assembled mBot Neo x 1
  • USB cable (Type-C) x 1
Assemble mBot Neo, connect CyberPi to the computer by using the cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3   Programming
Add mBot2 shield from the Extension center, and then program with the blocks added.
Part 4   Practice
What is the value of acceleration that maximizes the distance of movement for mBot Neo. Why is that?
1 out of 7 found this helpful
