Case 28 - mBot Neo rotates X°
Part 1   Objective
After you upload the program, toggle the joystick left and right to set the angle that mBot Neo rotates, and then press button A to start mBot Neo.
Part 2   Preparation
  • Assembled mBot Neo x 1
  • USB cable (Type-C) x 1
Assemble mBot Neo, connect CyberPi to the computer by using the cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3   Programming
Add mBot2 shield from the Extension center, and then program with the blocks added.
Part 4   Practice
You can measure the angle with an angle ruler to see whether the angle that mBot Neo rotates is the same as that you set.
0 out of 0 found this helpful
