Case 27 - Robot Moving Xcm Forward
Part 1 Objective
After you upload the program, toggle the joystick up and down to set the distance that the robot moves forward, and then press button A to start the robot.
Part 2 Preparation
Assembled mBot Neo robot x 1
USB cable (Type-C) x 1
Assemble the robot, connect CyberPi to the computer by using the cable, open mBlock 5 (PC client, web version, or mobile app), connect CyberPi, and select the Upload mode.
Part 3 Programming
Add mBot2 shield, and then program with the blocks added.
Part 4 Practice
You can measure the distance with a ruler to see whether the distance that the robot moves forward is the same as that you set.
