Case 26 - "Chameleon"
Part 1   Objective
After you upload the program, you can detect the color of an object by using Port R2 of the quad RGB sensor (the port at the far right), and then the screen of CyberPi displays the color value.
Part 2   Preparation
  • CyberPi-installed shield (powered on) x 1
  • Built-in quad RGB sensor
  • USB cable (Type-C) x 1
Install the above parts, connect CyberPi to the computer by using the cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3   Programming
Add Quad RGB Sensor from the Extension center, and then program with the blocks added.
Part 4   Practice
Try to use other features of the quad RGB sensor. The sensor also appears in other cases.
2 out of 5 found this helpful
