Case 24 - Use the ultrasonic sensor to detect distance
Part 1   Objective
After you upload the program, you can detect the distance (at a range of 5–300 cm) with the ultrasonic sensor.
Part 2   Preparation
  • CyberPi-installed shield (powered on) x 1
  • Built-in ultrasonic sensor
  • USB cable (Type-C) x 1
Install the above parts, connect CyberPi to the computer by using the cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3   Programming
Add Ultrasonic Sensor 2 from the Extension center, and then program with the blocks added.
Part 4   Practice
You can set funny ambient light effects with the Ultrasonic Sensor 2 blocks. Set it now.
1 out of 1 found this helpful
