Case 23 - Control the Rotational Speed
Part 1   Objective
After you upload the program, you can control the rotational speed and direction of the motor connected to Port EM2 by rotating the motor connected to Port EM1.
Part 2   Preparation
  • CyberPi-installed shield (powered on) x 1
  • Wheel-installed encoder motor x 2
  • Motor cable x 2
  • USB cable (Type-C) x 1
Install the above parts, connect CyberPi to the computer by using the cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3   Programming
Add mBot2 shield from the Extension center, and then program with the blocks added.
Part 4   Practice
Try to program with other motor-related blocks.
4 out of 7 found this helpful
