Case 16 - [Land Raider] Following
Part 1  Objective
After you upload the program, Land Raider goes straight forward. When the object to be followed is 40cm or less ahead, Land Raider starts following it. When the object to be followed is over 40cm or less than 8cm, Land Raider stops moving.
Part 2  Preparation
  • Assembled Land Raider x 1
  • USB cable x 1
  • Connect the ultrasonic sensor to the 6th connector of Auriga
Connect Auriga to the computer by using the USB cable, open mBlock 5 (PC client, web version, or mobile app), connect CyberPi, select the Upload mode, and press the red button to turn on Auriga.
Part 3  Programming
Part 4  Practice
With the ultrasonic sensor and track, Land Raider can follow objects. What can you do with them and other sensors to make Land Raider do something interesting?
0 out of 0 found this helpful
