Part 1 Objective
After you upload the program, Land Raider goes straight forward. When the object to be followed is 40 cm or less ahead, Land Raider starts following it. When the object to be followed is over 40 cm or less than 8 cm, Land Raider stops moving.
Part 2 Preparation
Assembled Land Raider x 1
USB cable x 1
Connect the ultrasonic sensor to Port 6 on Auriga
Connect Auriga to the computer by using the USB cable, open mBlock 5 (PC client or web version), connect CyberPi, select the Upload mode, and press the red button to turn on Auriga.
Part 3 Programming
Part 4 Practice
With the ultrasonic sensor and track, Land Raider can follow objects. Can you make Land Raider do something interesting with the ultrasonic sensor and other sensors?
