Part 1 Objective
After you upload the program, Land Raider goes straight forward. When it encounters an obstacle, it turns left or right randomly. After it runs away from the obstacle, it continues to go forward.
Part 2 Preparation
Assembled Land Raider x 1
USB cable x 1
Connect the ultrasonic sensor to Port 6 on Auriga
Connect mBot Ranger to the computer by using the USB cable, open mBlock 5 (PC client or web version), select mBot Ranger in the Device Library, select the Upload mode, and press the red button to turn on Auriga.
Part 3 Programming
Part 4 Practice
With the ultrasonic sensor and track, Land Raider can run away from obstacles. Can you program the RGB LEDs for different lighting effects when Land Raider avoids obstacles?
