Case 3 - Temperature Detection
Part 1  Objective
After you compile the program, the stage displays the temperature detected by the temperature sensor in real time.
Part 2  Preparation
  • Auriga x 1
  • USB cable x 1
Connect Auriga to the computer by using the USB cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Live mode.
Update the firmware of Auriga.
Part 3  Programming
Temperature detection: In Live mode, after you select the check box on the left of the temperature sensor onboard value °C block, the stage displays the temperature detected by the temperature sensor in real time.mr14.gif
Part 4  Practice
Change the temperature output value of mBot Ranger by changing the ambient temperature.
1 out of 1 found this helpful
