Part 1 Objective
After you compile the program, the stage displays the temperature detected by the temperature sensor in real time.
Part 2 Preparation
- Auriga x 1
- USB cable x 1
- Computer with network access x 1
Connect Auriga to the computer by using the USB cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Live mode.
Update the firmware of Auriga.
Part 3 Programming
In Live mode, after you select the check box on the left of the temperature sensor onboard value °C block, the stage displays the temperature detected by the temperature sensor in real time.
Part 4 Practice
Change the temperature output value of mBot Ranger by changing the ambient temperature.
bnnm
yyea
