Case 1 - Control the LEDs
Part 1  Objective
After you upload the program, the LEDs on Auriga blink, light up one by one, or are displayed in other ways as programmed.
Part 2  Preparation
  • Auriga x 1
  • USB cable x 1
Connect Auriga to the computer by using the USB cable, open mBlock 5 (PC client or web version), connect CyberPi, and select the Upload mode.
Part 3  Programming
  1. RGB LEDs blink: when you turn on mBot Ranger, the LEDs are on and off alternately.mr5.gif
    1. RGB LEDs light up one by one: when you turn on mBot Ranger, the RGB LEDs light up one by one. After all the LEDS are on, they go off.
Part 4  Practice
      1. Try to change the light color of the LEDs.
      2. Try to make the LEDs light up and then go off one by one.
15 out of 21 found this helpful
1 comment
  • How do you use the center button ?
