mCore – Main Control Board of mBot
Overview
mCore is an easy-to-use main control board specially designed for mBot. Based on Arduino Uno, mCore integrates various on-board sensors, such as a buzzer, a light sensor, RGB LEDs, etc., which provides you with an easy way to start learning electronic modules.
Features
  • It supports Arduino and Makeblock Library for easy programming.
  • It integrates various on-board sensors, such as a buzzer, a light sensor, RGB LEDs, etc.
  • It has a USB Type-B port which can be used for a long time.
  • It is equipped with resettable fuses which can prevent the circuit from burning.
  • It has 4 RJ25 connectors with color tags, enabling mCore to be connected to more Arduino sensors.
Specifications
  • Operating voltage: 3.7–6 V DC
  • Microcontroller: ATmega328
  • Product dimensions (L x W x H): 90 mm x 79 mm x 18 mm
  • Package dimensions (L x W x H): 110 mm x 150 mm x 10 mm
  • Net weight: 43 g
  • Gross weight: 47 g
  • Package content: mCore x 1
77 out of 100 found this helpful
1 comment
  • I just got a mBot and it doesn't know if it is picked up. Is there any way to diagnose the problem?
